Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Not enough base under clear coat!
Old 11-23-2007, 09:08 AM
t66turbocobra's Avatar
t66turbocobra t66turbocobra is offline
The best way to get tight areas. is to start of with those area first then go back and spray the entire piece as if there was no tight areas. That way, the tight areas are already coated and now u just have to worry about the visible area. When it come to using the gun in tight areas. Turn the air pressure down and adjust the fan pattern as needed. This will provide a even coat over the entire peice.
