Originally Posted by shad9876
very good technique.
Would a sealer help me in this situation? Could I reseal the entire frame and then shoot over the sealer or would this only create more problems with solvents getting trapped under the sealer?
How long will it take for the finish to cure sufficiently so that the new paint won't be able to penetrate the existing paint?
It doesnt matter if u seal the frame or not. The amount of paint that gets in the tight areas depend on the painter.
Once the clear has set and hardened; you can repaint the part. The time it takes to dry depends on the air temp and the hardener. Also if ur in a garage or booth
