Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Not enough base under clear coat!
Old 11-23-2007, 02:36 PM
t66turbocobra's Avatar
t66turbocobra t66turbocobra is offline
Originally Posted by shad9876
i was also told by a paint shop rep that i should have used a catalyst in the base. he says that this would have allowed me to simply scuff and reshoot without worrying about solvent pop. When i repaint, should i use a catalyst?
Yes he is right. U defiantly want to use a reducer with the base coast. Make sure u choose the right reducer for the temp u will be sparying in. It sould be mixed to a 1:1 mixture. Simply use a mixing cup for this. Plus your paint will go a longer way.
