not enough turn? HELP!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2009, 04:13 AM
ajbcc2's Avatar
Last journal entry: frankenstude too
I have a dodge omni rack for steering a 34 ford coupe frame. I have the steering arms from Speedway that bolt onto chevy style spindles. I used the holes that were in the arms to mount the ends of the rack to,but it doesnt appear to turn enough. I measured on my dodge truck from the frame to the inside of the front tire and got 15 inches (while straight)then turned all the way and got 23 inches. This being about 8 more inches of travel (from being straight)i figured was almost 33% more movement from the frame. on the coupe it was just under 25%.
Would it be ok to leave alone(not my best choice) or should i shorten the steering arms to get more turn?or drill new holes closer to the pivoting point?
(shortening or moving the holes means the rack ends will hit the brakes hoses on the calipers so the arms will have to be bent downwards also)
Old 06-17-2009, 06:51 AM
powerrodsmike's Avatar
Wiki Edits: 161
Is this a rack mounted on a straight axle?
Mikey
BE different....ACT normal.
Just wont light. Nsomnia Engine 16 09-15-2008 03:07 PM
Turn signals quit working wolfeman Electrical 1 09-09-2008 07:54 PM
Valve lash question motorhead454 Engine 3 09-01-2008 11:08 PM
Timing a 350 oke02206 Engine 1 08-03-2008 01:27 PM
no turn signals fasteddiesage Electrical 9 12-16-2005 04:04 PM
