Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Not a everyday Hotrodder question...
Old 08-20-2012, 10:45 AM
AutoGear AutoGear is online now
Has the outdrive been services? Does it have the proper lubricant? Do you have the proper...propeller? It sounds like its not the engine. If you blow the outdrive completely; its going to be a bad day. Take the boat to a marine mechanic and have them inspect the O/D. If you guys are fairly equipped mechanically, you can do the service yourself. Id see if theres a copy of the service manual on the web, and see if its something you want to tackle.
