Not a everyday Hotrodder question... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-20-2012, 05:16 PM
Alright thanks all! I will look into it!
  #17 (permalink)
Old 08-21-2012, 09:32 AM
make sure you let us know the outcome! good luck!
  #18 (permalink)
Old 08-21-2012, 05:43 PM
LATECH's Avatar
The mainshaft bearings in the outdrive (where the crankshaft hooks to) are a pretty good suspect. It turns all the time with the engine running . Ive seen several that had bad bearings and cause the loss of power from the engine when trying to operate the boat. When the bearings go bad , they can seize up,causing the engine to bog,also chewing up the housing as the locked up bearing spins in its bore.Not pretty.
It should be easy to check with the engine out.
Fact is stranger than Fiction
  #19 (permalink)
Old 08-21-2012, 06:00 PM
Alright we will check all! The mechanic kept it under warranty so we will know hopefully by the end of the week!
  #20 (permalink)
Old 08-28-2012, 02:10 PM
hey guys! Just a quick update and we found out that the valves weren't closing all the way which would not let the engine start...We just tore off the head and did it ourselves! Thanks again to all!
  #21 (permalink)
Old 08-28-2012, 04:56 PM
LATECH's Avatar
Originally Posted by 79bird View Post
And its turned on before, but the mechanic that we hired took it to his shop and lifted the engine out and it ran good, but its progressively getting worse, now it wont even turn over.
I guess we should have clarified the statement a little better. A few of us were under the impression that the engine would turn or "turn over" as you put it.. What you meant was it turned over but wouldnt start up...Right ?
Maybe we should develop a thread in general hotrodding about terminology and word usage so we all can get on the same page.
timing off *2 for everyday tomthecomic Engine 2 04-26-2008 12:31 PM
Learn something new everyday... Nightfire Hotrodders' Lounge 28 06-20-2006 02:06 PM
You learn everyday. BarryK Body - Exterior 29 03-30-2006 06:03 PM
Here is something you don't see everyday..... onebadmerc Hotrodders' Lounge 6 10-21-2004 11:50 PM
Not your everyday ad arch Hotrodders' Lounge 7 08-06-2004 12:49 AM
