Not a everyday Hotrodder question...
Hey guys,
Me and 5 of my friends decided to buy a boat as an summer project (Yes it was a big mistake lol), but now we have everything done, new plugs, electrical, lines ect...So for the first time we take it on the water, and we rev to about 1500 RPMS it starts to shake and past a certain point it'll backfire and pop and refuse to rev higher. Any ideas? Thought it might be from the Carb being too lean? Or fuel pressure? Its a 2.5L I4 Chevy with a 1BBL..Thanks! It also has a hard time turning over right after, we have to wait an hour or so for it to be able to turn over.The revs it was able to obtain got worse and worse |
No the firing order is right, and we had to take it to a mechanic at one point and they said they did the timing on the dot...So I dont think that timing is an issue, it runs like a clock at idle speeds, before it stalls at higher RPMS
can't delete this
Alright..Thanks guys for your input! Were going over to the boat today and will just do a quick run through of items that you all said.
I would take a WAG.......old stale gas!!!
Fact is stranger than Fiction |
Does it have enough oil?
it has oil and a tune up. the gas is new too. we took of the distributer cap and one of those 4 brass things had broken in half. Could that be it?
And its turned on before, but the mechanic that we hired took it to his shop and lifted the engine out and it ran good, but its progressively getting worse, now it wont even turn over.
The outdrive unit is freezing/siezing up.
Has the outdrive been services? Does it have the proper lubricant? Do you have the proper...propeller? It sounds like its not the engine. If you blow the outdrive completely; its going to be a bad day. Take the boat to a marine mechanic and have them inspect the O/D. If you guys are fairly equipped mechanically, you can do the service yourself. Id see if theres a copy of the service manual on the web, and see if its something you want to tackle.
| timing off *2 for everyday | tomthecomic | Engine | 2 | 04-26-2008 12:31 PM |
| Learn something new everyday... | Nightfire | Hotrodders' Lounge | 28 | 06-20-2006 02:06 PM |
| You learn everyday. | BarryK | Body - Exterior | 29 | 03-30-2006 06:03 PM |
| Here is something you don't see everyday..... | onebadmerc | Hotrodders' Lounge | 6 | 10-21-2004 11:50 PM |
| Not your everyday ad | arch | Hotrodders' Lounge | 7 | 08-06-2004 12:49 AM |
