not exactly hot rod car problem but... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 03:40 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
a hotrodder's truck, please tell me what's going on with my 4X4 '99 ford explorer's 5 speed auto tranny, it won't manual shift to low when driving downhill, when the low position is selected the trans disconects and freewheels (scary when engine braking is needed most) but if the car is not moving and low is selected it starts and accelerates normally, when I release the gas the trans disengages again, second and drive are normal, fluid color and smell normal, no sludge in the oil pan, everything look OK, please help I need the low gear a lot living here in the mountains.
Thanks
Augusto.
Old 04-15-2006, 06:38 PM
airworld2's Avatar
99 explorer
mileage? mlp switch, solenoid or valve body. just a guess
airworld2
Old 04-16-2006, 07:15 PM
Augusto's Avatar
MLP switch? never heard of such critter, what is it? the truck has 84k miles.
Augusto.
Old 04-16-2006, 08:24 PM
airworld2's Avatar
explorer
switch on the side of tranny case. driver side, bolted to the case 2- 8mm screws on the linkage shaft.
airworld2
Old 04-17-2006, 07:05 AM
tnsmith10's Avatar
when will it rain???
think of it as an old neutral switch, like from a c-6 or c-4, but does more than a neutral switch..
like airworld said, its on the drivers side of the case, slides over the manual arm, 2 8mm, hex head bolts. make sure to go with a genuine ford switch, they r more reliable than a aftermarket switch. gl.
Old 04-17-2006, 05:50 PM
Augusto's Avatar
yep I think I know what your talking about, it's that switch that's used in the early trans to turn the backup ligths on and prevent the motor from starting in gear, I belive your telling me this thing sends the signal to the control module to energize a solenoid that shifts into low, am I rigth? pretty simple ain't it?
thanks.
Augusto.
Old 04-17-2006, 08:14 PM
airworld2's Avatar
explorer
wait a minute, before you jump the gun start by having your truck scanned for codes. just replacing parts may not solve the trouble.
airworld2
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 02:27 PM
Hot Rod w/ a Japanese engine and transmission and a passanger car frame alex_0227 Hotrodding Basics 27 05-28-2005 02:07 AM
Classic Hot Wheels Good Condition or New COndition ArchonRacing Engine 2 02-22-2005 12:19 AM
Old Hot Rod Car Radios Sean_J Hotrodders' Lounge 3 07-02-2002 03:42 PM
