Not happy with edelbrock e street heads
Hi guys i built a 355 with flat tops(9.5:1), comp cam xe 224/230 a set of 64cc edelbrock e street heads and a edelbrock 1406 carb(rejetted) brand new msd dizy. Im not happy with the performance at all, im thinking heads arnt the best....looking for any advise of what to change i was looking for the 375hp mark....thanks alot...
Mark |
Tell more. Did you install the cam straight up, what's your timing, what ignition, exhaust? Trans and gears? Vehicle information, weight, etc.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Cam is on standerd time, base timing 14 total timing 36 , dizy is a msd street fire, intake is a 2101 edelbrock performer. The engine is in a 73 camaro weight......3300 lbs...im guessing th350 tras 2500 stall 373 posi
Thanks |
hooker headers and duel 2 1/2 old flomaster mufflers
my guess would be, you need more cam and a better intake (Performer RPM)
I think the heads are OK, but I'm no expert there are some more guys with better info, around here |
Thanks alot for the replys, can anyone recomend a good book on porting and polishing heads? The other problem i think i might have is hood clearance with a bigger intake and i dont want to change the hood.
Get a RPM style dual plane hi rise intake and 750cfm carb.
re-curve the distributor for 24deg initial (at idle) and 34-36 total (in about 2,400 rpm.) get a 10" 3500 stall. Degree the cam to verify valve timing points. Move it if necessary. 2.5"-3" pipes and flow-master mufflers i think the heads are fine, i've seen them make killer power out of the box. |
the heads will have no problem with 400hp. the camshaft can get there too. the induction and exhaust could use some work. more initial timing will help low end torque but won't change peak HP.
Heads are not the hole issue.
the carb and cam are moderate. Not capable of making good solid HP. A better cam and carb will make better use of the heads. Your build is moderate build, your only going to get moderate results. IMHO Al |
You need to start looking at other things before you do anything with those heads. Maybe the advance in your new distributor is sticking, or the secondaries aren't working, etc...
You should look for a place that will dyno tune it as it is now |
The RPM intake is my least favorite. Never made more power than the perfomer on mild engines.
Using the entire Edelbrk RPM package it works like a fine tuned instrument. The torquer 2 is the -6000rpm low rise single plane. If your build was between the performer 350 package and the RPM 350 engine package, that is my choice. Fits under a lot of the low hoods. |
Wrong carb, wrong intake. You need a 750 on an RPM AirGap.
| Edelbrock Performer EPS or a Holley Street Dominator. | adantessr | Engine | 15 | 11-04-2011 05:40 PM |
| Edelbrock Performer EPS or Holley Street Dominator. | adantessr | Hotrodding Basics | 2 | 11-03-2011 01:11 AM |
| Edelbrock Victor Jr intake street manners | v8hed | Engine | 48 | 07-23-2011 11:38 AM |
| Setup up of Edelbrock Street Tunnel Ram | silverT | Hotrodders' Lounge | 1 | 03-09-2006 09:33 AM |
| Edelbrock Street Master Intake? | Kenny13z3 | Engine | 7 | 11-02-2004 10:34 AM |
