Not happy with performance from new 355. - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 07-17-2013, 12:02 PM
F-BIRD'88's Avatar
Yada Yada Yada
Ya don;t get less than a 4.88 gear and ditch the spool
Yup go to the track and run it.
1/4 mile ET is 1/8th x 1.57
1/4 mile MPH is 1/8th x 1.27.
The MPH tells the tale.
weight the truck on a scale with you in it.
(true weight to power ratio)
This truck needs a supercharger.
  #32 (permalink)
Old 07-19-2013, 05:42 PM
bigdog7373's Avatar
Of course it's fast
I don't think you realize how heavy 4000lbs is. It takes a lot of power to move that. You're making around 350 crank hp, so like 300 at the wheels. 14's is pretty darn good for what you have. You need forced induction or shed a bunch of weight to make it into the 13s
You should get it dyno'd as it sits right now. Its like $60 and hour or something, and its well worth it. You can get it tuned perfectly and make sure you're getting every drop of what the motor can give.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Best heads for street performance 355 adantessr Engine 15 02-17-2013 08:09 PM
SBC 355 Performance Build ChevroletSS Engine 103 12-21-2012 06:10 AM
AFR dyno comparison on their 355 vs my 355 black66 Engine 21 10-13-2009 04:57 AM
Performance Heads add in Chevy Hi Performance sdimpala64 Engine 1 04-29-2008 08:59 AM
Happy Birthday to you, happy birthday to yooooooooou.... Nightfire Hotrodders' Lounge 4 10-26-2004 12:05 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
