Not a hotrod but - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2005, 04:41 AM
1981monte's Avatar
Not a hotrod but
My girlfriend has a 1995 Olds cutlass Ciera Well anyway she is driving me crazy about her anti-lock brake light staying on. Anyone know how to figure out why it is on, is there a way to check codes like the ecm. so I can fix this thing. Any advice will be greatly appreciate!! then maybe I can get lucky again
Old 03-27-2005, 07:58 AM
ZipZ28's Avatar
Nitrous Junkie
Last journal entry: Reflooring The Bed Pt. 2
I'm sure most of the major auto supply stores can read the codes for you, I know AutoZone does it and I think O'Reilleys does too.
Old 03-27-2005, 08:41 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
the first thing i'd do is check the brake fluid. as the pads wear, the fluid level goes down, often enough to the point of tripping the brake lite. if the fluid level is low, you can pretty much rest assured that it's time for a brake job sometime in the near future.
if the fluid isn't low, do like he said, go to CSK oreillys, or a zone and borrow their code checker.
Old 05-09-2005, 03:40 AM
1981monte's Avatar
Went to auto zone they say that they can not scan abs systems. Have the dam book on the car but it does not give much info on the abs systems, just wondering if there is any GM tec.s out there that know the system on this car
Thanks Monte
Old 05-09-2005, 09:50 PM
abstruse dutch uncle
Besides low fluid, if a brake lamp is out, it might make the ABS light come on, including the 3rd eye light.
Check the wires to the speed sensors and check the wheel bearings. If there was any work at the wheels right before the light came on, check the sensor rings and pickups for alignment and crud.
That's all the simple stuff I can think of.
Old 05-11-2005, 09:10 PM
1981monte's Avatar
Will do thanks, let you know
Old 05-12-2005, 01:53 AM
Malibucdl's Avatar
Laissez les bons temps rouler
Last journal entry: Frame Removal
Check the wheel speed sensors and their connectors. If I am not mistaken, if they are bad and need to be replaced, the whole wheel hub needs to replaced as they are sealed units. I have heard of this similiar problem over on www.N-body.net. Just something else worth looking into.
Chris
So What is A Hotrod Ratchet Hotrodders' Lounge 63 10-05-2006 01:11 PM
Why your hotrod is better'n your... 66Caprice Hotrodders' Lounge 25 07-15-2004 10:15 PM
poll: original or hotrod 2112jb Hotrodders' Lounge 19 05-19-2004 07:23 AM
HotRod Parts Mfg's Weimer Hotrodders' Lounge 3 02-01-2004 10:27 PM
Favorite HotRod Site? Weimer Hotrodders' Lounge 21 11-13-2002 09:39 PM
