Not hotrod... Ford Van rear axle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2011, 12:09 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I'm bidding (ebay) on a 2003 E350 ford van with a 7.3 'stroke. I've figured out everything I want to know except the rear axle.
Its (obviously) an 8-lug rear and I assumed it would be a 10.25" Sterling, but some sources are telling me its a 9.75". I had no idea that a 9.75 was ever an 8-lug, but I've never owned the van version.
GVW is 9600. Axle code is C9, but all that tells me is that its a 3.55 posi. I'm not sure I really care which one it is, I just want to know.... ya know?
Old 04-24-2011, 08:51 AM
LATECH's Avatar
I am seeing that the 9.75 is a replacement design for the 8.8 in vans and trucks. Only thing I see is it comes as a heavy duty replacement for f 150 E 150 and the like. A 5 lug pattern.I did not see anything with a 9.75 and an 8 lug pattern, only the 10.25 . Door codes tell what ratio and type axle. Anything that starts with a letter is limited slip.There may be more info out there about the 9.25 but I didnt see anything about one used for anything over a 150 rating.
Will this be the new service truck?
Old 04-24-2011, 08:52 AM
from all the research i gathered you have a dana 70 housing machined to fit dana 60 internals.
should be a semi floating and have a 70 stamped in the rib on the passenger side.
the econoline vans only came with the dana axles f series got the sterlings
LATECH's Avatar
here are some pics of the covers that may help.
Old 04-24-2011, 12:36 PM
prostreet6t9's Avatar
Differential/Driveline
Dana diff has a 10 bolt rear cover and the Sterling will have a 12 bolt cover. The 9 3/4 was not used in a E350. Anything 99 or newer will actually be a 10 1/2 if its a sterling.
If its a 10 bolt cover,ask for the BM number off the tag or axle tube.
12 bolt cover its a sterling.
There was some Dana 80's used starting around 2000 also.
Ford rear axle codes jake_arcticcat Transmission - Rearend 11 10-01-2008 10:24 AM
Ford 9" rear axle crownver Transmission - Rearend 5 01-24-2006 07:25 PM
31 ford with the original rear axle?? 31"A"bones Transmission - Rearend 3 09-05-2004 04:47 PM
1940 ford rear axle broaddua Transmission - Rearend 4 12-05-2002 10:58 AM
8" Ford rear Axle Ron Fowler Suspension - Brakes - Steering 7 04-26-2002 10:20 PM
