not a hotrod just electrical i believe.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2012, 07:13 PM
im driving a 1988 626 mazda thats great on gas.The only problem is sometimes when i try to start it all it does is make a click and then nothing.. ive replaced starter, and the battery is charged it just wont start.. Other times i can drive it all day long start stop.. turn on turn off and it works just fine.. Any idea what it could be?
Old 09-29-2012, 08:06 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Clean the battery cable connections. Remove them, scrape with a knife and replace and tighten the bolts.
If that doesn't work, replace both battery cables.
The solenoid is likely Ok because you hear the clicking sound.
The starter circuit is very simple. Battery, cables, starter.
Even if the cables look good there is still a possibility that one of the connectors is corroded. Very common.
vicrod
Old 09-30-2012, 10:46 AM
LATECH's Avatar
It may have a problem in the nuetral safety switch, or clutch switch if standard shift. That would be the only other thing I could think of beside what Vicrod said. They are pretty simple ...good thing huh..
Next time it happens, hold the switch in the start position and move the shift lever (automatic) through park to neutral and back, it may crank . That would give a good indication of the problem. If it is a standard, hold switch in start and move the clutch pedal up and down to move the switch. Once again if you get some action from the starter as a result, then your on top of the problem
Fact is stranger than Fiction
not hotrod but need help bigtank05 Engine 1 04-21-2009 08:11 PM
First Hotrod Maverick88 General Rodding Tech 4 09-17-2007 09:17 PM
Not a hotrod but 1981monte Suspension - Brakes - Steering 6 05-12-2005 01:53 AM
Not a hotrod, but an electrical problem adrock430 Electrical 5 04-05-2005 08:26 PM
Why your hotrod is better'n your... 66Caprice Hotrodders' Lounge 25 07-15-2004 10:15 PM
