not a hotrod question, changing a wheel bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2007, 06:51 PM
TailGater's Avatar
Blood, Sweat, and Gears!
Hi guys
My daily driver has a bad front wheel bearing (2000 Neon) I would like to change it myself if its possible but i think the wheel bearings are pressed into the hub on these cars, is there any way I would be able to change this without a press? I'm guessing I'll have to take the hub to a shop to get it changed but I thought I would ask you guys first.
Thanks in advance for your help,
Chris
Old 04-17-2007, 07:09 PM
I think you will need to take the hub and the new bearing to a shop with a press
Old 04-17-2007, 07:25 PM
Wiki Edits: 31
my mom has a '02 concorde, with an air hammer and a lot of time, we knocked them out, used long bolts to draw the new bearings in. backyardish but, we don't have a press. did the same with her '94 Concorde
Old 04-18-2007, 07:51 PM
TailGater's Avatar
Thanks matt167, I'll see if i can rig up something like that, if i cant get it to work I'll take it to a shop.
Chris
Bearing question for 10bolt rear killerformula Transmission - Rearend 9 05-25-2005 02:44 PM
Question about hotrod insurance SAATR Hotrodders' Lounge 9 11-17-2004 12:33 PM
Gm Wheel Bearing Problem scott011422 Suspension - Brakes - Steering 6 07-11-2003 07:41 PM
Wheel Spacing/ Mustang II Question Jackyl General Rodding Tech 1 04-25-2003 07:10 PM
steering wheel bearing for 72 chevy any one know where to find one? 72 chevy elcamino Engine 2 10-13-2002 06:18 PM
