guage
gm had a recall on their panels for that era- if you have less than 75,000
miles check with a dealer it may be covered. If it has over 75,000 miles there are services that can repair your panel or sell you a rebuilt one. Jim |
I would ground the sender lead to see if the gauge goes full, with key on. If it does, its probably a bad sending unit. But its good to check the BCM and ECM for codes and data too. But usually the fuel codes will make the fuel gauge read empty, if possible. And this wouldn't always set a check engine light.
If you had a scanner and the fuel % on data-stream said its 25% full but its stuck at 3/4 full on gauge. Then that might lead to some more difficult diagnostics. |
| Crankshaft Coalition: Master List of Hotrodding Forums | Jon | Hotrodders' Lounge | 38 | 01-20-2006 10:47 AM |
| New Forum: Advanced Hotrodding | Jon | Hotrodders' Lounge | 3 | 04-20-2004 09:40 AM |
| New Forum: Introduction to Hotrodding | Jon | Hotrodders' Lounge | 5 | 09-25-2003 09:43 PM |
