Not on level ground - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2003, 12:13 PM
Post Not on level ground
Ok I need a solution to a problem that I am having, unfortunately my garage is not level, instead it is actually sloped towards a center drain. I need to figure out a way to level my car on the ground to take measurements off of. I have all the measurements into a fabrication shop in Az to make my new front end, but when it arrives I will need a way to line everything up. Any thoughts. I just came up with the idea of using the ceiling since that is still more level than the floor. Input?
Old 04-21-2003, 04:11 PM
adtkart@aol.com
Post
Since you need a level reference to measure from, you might try a string. I would check the roof/ceiling closely. With a garage they are not always that precise either.
Old 04-22-2003, 04:56 AM
Dragon J's Avatar
Last journal entry: Harley/Fire
Post
Harbor Frieght has a laser level for $12- I'd get a good reading with a laser level and mark your levels on the walls. Then go from there to shim frame, etc to line up. I did my alignment that way and it handles great now.
Old 04-22-2003, 07:05 AM
Post
Actually the engineers that I work with came up with another option, actually using a water level. I did not think of that, but it certainly will give me the numbers that I am looking for.
