Not satisfied - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2011, 10:36 PM
Not satisfied
I have a 80 caprice with a 350 bored 60 over with 100 shot on it . With 373s posi it ran I'n the low 8s. So I put some 456s and a mini spool and my time got slower. So can someone help me figure out y
Old 05-18-2011, 12:17 AM
techinspector1's Avatar
Wiki Edits: 326
What's the static compression ratio?
Give all the specs on the cam, heads, intake and carb.
Old 05-18-2011, 06:01 AM
SSedan64's Avatar
And what Trans is being used?
Old 05-18-2011, 10:31 AM
Th350 with quick shift
Old 05-18-2011, 10:41 AM
cal1320's Avatar
Post your 60' times and incrementals with MPH and final ET.
Old 05-19-2011, 10:29 AM
S10xGN's Avatar
Gotta love a turbo!
*If* that 350 is stock with only a bore job and a 100 shot, you're way out of RPM in the 1/4. Prolly good to go for the 1/8 mile though...
Russ
Old 05-19-2011, 11:13 AM
Heads
It appears you ran out of engine with the 4.56 cogs. The first place I would look for improvement is the cylinder heads.
not satisfied with my power STUFF D Engine 4 06-29-2010 02:45 AM
Home Built and never satisfied. psy4s Introduce Yourself 4 02-02-2008 10:33 PM
never satisfied i had to get a 340 cuda66 Engine 1 02-22-2004 03:42 PM
Another satisfied customer...so far redcamaro4spd Transmission - Rearend 0 11-10-2003 09:01 AM
