not satisfied with my power - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2010, 12:09 AM
i have a 1973 chevy impala convt. i pulled the original 400 had it bored .30 over to make it a 406 installed all new parts on the short block including a new balanced crank the heads are dart ss with fast burn chambersthe cam only has 420 lift the intake is an edlebrock performer the carb is a holley street avenger 670 cfm i didnt do any work to the trans or rear end
before i pulled the engine iti could atleast power brake and smoke the tires now it just boggs what am i missing or need to do
Old 06-29-2010, 12:41 AM
sickboy84's Avatar
first you need to check your rear end, a better relation and a positive rear end its what you need to feel the acceleration and belive me, its a big diference, you will burn the tires faster and maybe you will need more fuel y think a holley 750 its not to much for your engine, and the trans its a bigger factor to put your hp in the ground so you should start from the rear end, the trans, and the engine at the end.............
i hope be helpfully for you......
Old 06-29-2010, 12:57 AM
thanks any gear ratios come to mind the will only be cruised occasionaly but i want to smoke the tires off
Old 06-29-2010, 01:39 AM
sickboy84's Avatar
this page can help you
http://www.car-videos.net/tools/spee...B1=Recalculate
this page can tell you the top speed with any tire size, RPM limiter and gear ratio, remember if you got a 4.11 gear ratio you will eat your tachometer more faster but your topspeed will be lower if you put a 3.07 you will have a lot of topspeed but the rpm will be slower, just need to choose wich gear ratio its the good one for you thinking in your rpm limiter and the topspeed you want.... hope be usefull for you!
Old 06-29-2010, 02:45 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
X2 as far as the gears and tranny. Pointless to rebuild a strong motor and leave the tranny out. I'm sure its the original tranny and rearend too. You can take a bone stock 305 and rebuild tranny and replace gears to say a 3:42. You could smoke the tires and cruise at decent rpm. Point is, too much hp not getn to the ground
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 10:12 AM
chevy 350 jimang22 Engine 4 07-14-2007 04:49 PM
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 11:09 AM
Advise on Porta Power choice meanroy Body - Exterior 7 06-24-2004 12:38 AM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 03:05 PM
