Not sure which board is best? Gas tank neck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2007, 08:14 PM
Hey guy, I didn't know which board to use. You can move it if you like. But my question is, Can you use a radiator hose to make a hose for the gas tank neck. I am told they will absorb the gas and ignite. Is this true? Is the hose for the gas neck a special hose? thanks
Old 11-25-2007, 08:18 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Wrong stuff, it will swell and get weak. A few parts stores have some diameters in straight lengths.
Old 11-25-2007, 08:48 PM
Last journal entry:
I would have to agree. I believe the ethenol in gas will make the rubber dry up and crack, which would in time make it leak.
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Yup, its special hose. The rubber in radiator hoses will die quickly. NAPA sells the proper hose... or at least they did 2 years ago.
Old 11-25-2007, 08:54 PM
Thanks, I will check NAPA tomorrow. The guy I spoke with says a customer took a rad. hose anyway for his camper and when he came back by he told the counter guy that it ignitied and burned the camper up about 40 miles away on the interstate. Too bad. THANKS.
Old 11-26-2007, 08:11 PM
Well I finally went to my favorite salvage yard. Give $10 for everything from the door to the tank, including the overflow hose. Should have went there first. Thanks for the replies.
Old 11-26-2007, 08:38 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I have used radiator hoses for years, they work very well, don't swell or ignite that's bs, what they do with time is get very hard, in order to remove them they need to be cut and split, I usually use the universal accordion like type hoses.
Augusto.
Gas Tank Filler Neck options? JhnBrackett Body - Exterior 10 09-05-2011 10:40 PM
Gas tank relocation, dumb idea? Gearhead forever General Rodding Tech 3 10-26-2005 06:51 PM
Gas Tank .... problems 63novawagon Body - Exterior 1 04-25-2004 12:26 PM
Gas Tank Cleaning/Flush? The Vandal Engine 8 04-13-2003 10:27 PM
replacing gas tank in 29 Ford pikalpha Engine 2 12-10-2001 05:45 PM
