Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Not sure how to tackle seat mount problem
Old 08-22-2006, 05:49 PM
DrChop DrChop is offline
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
Make the floor plates...
out of 3" square by 1/4" thickness minimum, and drill/tap the mount hole in the middle 3/8-NF thread. Only ONE threaded hole in the plates. When you know where you want the plates drill your mount hole thru the floor 13/32" and around the hole drill 4 smaller holes at least 5/16" dia. Mount your seat and snug up the bolts into your plates under the floorpan, then rosette or plug weld thru the smaller holes in the floor to anchor the threaded plate directly centered under each mount bolt. Nice and neat.
