Notched frame, did I weaken it??
Ever make one of those late night decisions that turned your stomach the next day? I'm in one of those situations. Against my better judgement I notched the frame to make room for the headers. I'll have actual pics tomorrow, but I got a drawing and some links to get the discussion going. I need to know if (A) I need to do plate welding to strengthen up the rails or (B) I'm cool and I can 'go with it', which I doubt.
The frame mounts for the motor mounts are bolt on. There is no crossmember. They hang low in the frame, but do have an angled bit of plate that extends into the frame for support - hard to explain, see pictures. Directly behind the frame mounts is where the notching took place. I did not notch the bottom of the rail, just the top. The paint drawing is a birds eye view, with a side view of how the frame mounts work down at the bottom. This is a AD series 49' Chevy truck frame, which are pretty tank-like. But any big notches in ANY frame is a bad idea. I see no way to do any kind of conventional boxing, so what methods am I looking at for making this safe? It doesn't have to be pretty. Just safe. At first I was really freaked out, but hey - this is hotrodding. Anything can be fixed. FRAME MOUNTS PICTURE (LARGE) ENGINE PICTURE (LARGE) |
I am no sort of frame guy, but that looks weak to me.
A guy I used to know dropped a V8 into a little ranger (common swap now, but back then....). He notched one frame rail similar to your left side to clear a header pipe. He took a piece of heavy wall pipe and welded it vertically in the frame (where your cut out piece is). Does that make any sense? You could do two pieces where the dual cutout is on your drawing. As far as the other side...no clue what you could put in there. Waiting on pictures. i want to see how this plays out. ![]() BTW: Where in AR are you located? Hopkins welding is in heber springs (I think). Last edited by Brian_B; 12-23-2006 at 02:17 AM. |
Noched frame
Cut some of the motor mounts (the leg going inside of the chassis) enough to allow you to place a 1/2 steel plate the shape of the inside of the chassis. Make it a reasonable length for support. weld.
As Brian B stated we need pictures. I can't remember where I seen this, " There are no mistakes only more welding" All Is not lost. ..russ |
Just looking at that 2nd picture with the engine in place....If you cut the tops of the frame rails, I would say that you weakened it immensely...............
Ontario Rodders |
You're right, Hopkins Welding is here in Heber Springs. Small shop, but nice guys.
I think I understand so far. Either I'm looking at verticle pipe welded in or a length of plate set back in the rail, sort of resembling an 'I' beam. I'll have pictures up around 7 this evening, I'd appreciate any more advice you all have. Thanks for the encouragement so far. Last edited by OKSoda; 12-23-2006 at 12:59 PM. |
frame notch.........
hi,first i would cut that protrusion off of the left frame rail.to make the opening a U shape. then i would take a piece of 1/4 in plate cut to the height of the cut out.bend and fit outside the chassis(in a vice) after getting close to the shape i needed i would weld it on 1 end. then using the torch and c clamps i would pull it into the chassis,welding it to top rail,and bottom to inside of chassis. DO NOT WELD ALL AT ONCE. good tacks only,do the same for other side. then i would go from side to side welding small amounts at a time,so i didnt warp the chassis. after securely welding, i would make a 1 /4 in plate and weld to the bottom of the chassis. at least 12 inches for and aft of the cutout....im boatbob2
Ok, got out to the shop today and it really is a mess. Yuck. I have a set of pics up in the project journal, take a look. I can further explain if anything isn't clear. Some of it is a little blurry.
PROJECT JOURNAL PICS |
I was not able to see whether you had also notched the bottom of the frame rails in your photos. The drivers side looks to be the most challenging to repair as you also have added a "box" in an even wider cut in the frame rail to mount the steering box. What you have now (as you already are aware, is not a good or safe situation) I think it would be easier (and better) to remove the headers (sell them) and weld the sections of the frame back in place. Then add plates to box in the inner portion of the frame rails from the front cross-member all the way back to about where the trans cross-member is located. The area where the steering box is located would have to remain open obviously. Fabricate your own custom headers to fit the repaired frame. Have you considered fender well exit headers? They would go over the frame rails. You have a lot of work ahead. Good luck and please continue your journal.
I definetly understand the best way to go is to lose the block huggers and replace all the material I removed. Esentially start over. But what about the method that boatbob2 describes here? I don't have a torch so any bends in the plate would have to be pieces that are arc welded together to make any curves or bends. I have few resources and little money left so making what I already have work is desireable. Someday all this, including the gearbox notch, will go and the whole front end with be solidly boxed in. If I can make this current situation safe and solid now it will at least keep the project moving. Oh, and thank you for adding the resized images. |
Your "someday" statement is the way to go now. Your welcome as to the photo resizing. The pictures in your project journal are still the same as what you uploaded. What I did was copy your originals to my computer, resized them, and uploaded them to my photo album so they could be posted in this thread. Easier for everyone to follow when the photo is right here. Keep us informed as to your progress. |
I believe the gear box notch was made to keep in line with the original steering column location, not because of engine clearance. U joints could have accomplished all that without the notch. Someday thats the way I'll do it.
I'll have to think about it and take all this into consideration. Simply put and to the point, I don't have the money and equipment to do it the right way. At least not right now. It's a hard truth. Unless I can psych myself up to really tear into it I may just have to go with the 'crushed box' idea. I guess if it was easy it just wouldn't be any fun! I want to hear anymore ideas you all have. Here's a sketch I made to clear it up some:
I understand that cashflow is an issue here, but you might want to consider
Sanderson's cast iron headers for that. about 3" is all the space they need. If you have a GEN V or GEN VI block there is some minor block grinding to make 'em fit. They actually take up less space than a stock manifold. I had to use them for the Gen VI 454 in the Elky---could find nothing else that would work. Bryan |
| 59 Chevy pickup frame woes! | Li'l Pine | Suspension - Brakes - Steering | 33 | 07-08-2009 08:24 PM |
| frame pics | willowbilly3 | Hotrodding Basics | 6 | 12-08-2006 10:25 AM |
| Critique My Frame | STATUTORY GRAPE | Suspension - Brakes - Steering | 23 | 12-21-2005 08:51 PM |
| Cantilever system for air bags | 53LEDSLED | Suspension - Brakes - Steering | 17 | 12-05-2004 03:26 PM |
| Body & Frame question | ruiner808 | General Rodding Tech | 7 | 09-14-2003 05:54 AM |
