We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-27-2002, 06:00 PM
tim28 tim28 is offline
New Member
Post nothin but trouble
well ***** i have another problem cure one get another i had touble with my starter grinding thought i figured it out but today the starter started its ***** again i pull the starter down and got to lookin around and there was a crack in the middle of the bolt hole where the starter mounts to the block i stuck a screw driver in the hole to see if it was cracked and i get a piece break off about 1/8 inch so i guess thats why the starter would never work right cause the starter would move on startup what can i do to fix this oh the crack was on the block its self any ideas
Old 10-31-2002, 03:24 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
1BAD80's barnstar
Wiki editor
Last wiki edit: How to adjust valves
Wiki Edits: 2
Post
wheres it cracked?bottom side?
Luv the smell of NITRO in the morning.
Old 11-03-2002, 06:01 PM
New Member
Post
its on the outside pad on the block where the starter mounts to
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
