I think you nailed it right at the end. The back of pickups are usually just too light to get good traction. Especially if you are putting plenty of power to them. I had the same problem with my '63 chevy. I took the floor out of the bed and welded in a new 11 gauge floor. It took four guys to pick up the bed, but I got a whole lot more traction. You might look at adding weight in the rear corners, like with sandbags at first and figure out how much you want to add before you do anything permanent.
Way back, I got my clock cleaned really good by an El Camino with a 427 that didn't have any traction problems at all on the street. Friends said that he had weighted his tail gate, and then secured it in the down position. He added very little overall weight, but the weight he did add was far to the rear of the vehicle. I would also go for sticky tires, maybe some BFG Drag Radials (or whatever favorite brand you have) in the largest size that fits comfortably . You will still be able to blow them away if you try, but they do add quite a bit more bite. If nothing else, start the race from a roll.
I had an 87 chevy p/u with a 454.. this went 13 flat on a very mild build. I went with the BFG drag radials which planted the tires very well 10 ft of tire spin compared to 800 ft with stock tires
My work truck was a warmed over 2X4bbl 440, it had trouble keeping the tires planted during roll-ons, and it was a 3/4 ton club cab!
I found improving weight transfer and launch technique were the only grasp at coming out of the hole well. |
Like stated previously, try adding weight temporarily.
Go easy with it, start at 150 pounds, and then add around 50-75 pounds at a time, just inside the tailgate, with a slight bias to the passenger side to counteract your weight in the drivers side. Stop when you have achieved the desired effect. |
Like everyone has alluded too, adding weight is one solution but, you really need to look at the whole combination. Weight, tires and traction devices. I would seriously consider a set of Cal tracs and some good drag radials to start THEN start adding weight to get your truck to hook up. Moving the battery to the right rear corner and taking the fuel tank out of the cab and putting a cell under the bed in back would also move the weight bias to a more usable location. Just some ideas but, to get the truck to work like you would like, will require addressing all of the issues.
Mark |
I have the same problem with mine. I plan to replace the 255/60s & put on 275/60s. I also plan to ditch the 4.11s for 3.73s.
When its time for this 454 to be freshened up Im gonna kill of some low speed torque intentionally for more mid & upper power. Infact I might yank the Performer intake off & put on a singlr plane. Itll spin posi for a city block if I let it . with a borrowed set of 9x29.5 slicks it ran a 13.80. with regular radials.with street tires Id be lucky to get a 13.80 60 ft. LOL. John |
