NOTICE............read me....by the Moderator - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 01-02-2005, 04:08 PM
Please only post questions and answers with a technical content. We have the basics and the lounge for just talking or dreaming about a project.
We have spell check........it is free. Please use it when posting a question or a response. It will tell you when your spelling is off and give you the right spelling to choose from.
It makes you look better. It makes you look more educated........ IMHO
It also makes reading your question or response a good bit easier...so you get a better answer.
Also........the advice you receive here is the advice of our members. Their experience levels vary. Some are ASE certified professionals. Some are backyard hobbyist, with less experience. You will need to evaluate the advice given before taking action. Just because someone says they did it......without a problem....does not mean it is a good idea or sound mechanical advice.
Example
If a member tells you they had a 540 cubic inch blown Big Block that ran high 7's in the quarter mile with a stock 10 bolt rear and a stock Turbo 350..... WITHOUT ANY PROBLEMS .... ..you might should reconsider the advice given......
Closed Thread
