noticed vacuum advance plate is loose affect anything? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2011, 04:46 PM
i was out in the garage today working on my distributer noticed the vacuum advance plate where the vacuum line goes from the carb into the distributor was pretty loose, just wondering if that affects anything? i searched for a while and couldnt find any answers
Old 06-12-2011, 06:19 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Yes it can be a (POTENTIAL) problem and it can definitely change how the engine runs/performs IMHO Is it acting up on you now ? sometimes they will be fine but not alway's the case. JMO
Cole
Old 06-12-2011, 06:48 PM
it runs ok besides not being as strong as it should, ive always thought the car had a timing problem and it seems every time i time it the timing is somewhere else, built it a while ago and sorta just gave up on tuning it cause it never performed anywhere near where it should
Old 06-12-2011, 06:54 PM
eloc431962's Avatar
Wiki Edits: 37
Yep i have had the same problem in the past and a new distributor really woke it up.JMO
Cole
_______________________________
If you never ask you will never know.
Opinions on ported of full vacuum for vacuum advance ? y2k600f4 Engine 15 10-07-2011 09:38 PM
Timing... vacuum or no vacuum advance? 454ChevelleMalibu Engine 18 04-25-2010 09:37 PM
Ignition Timing Affect Vacuum lanceks1 Engine 7 01-11-2008 02:10 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
computer advance or vacuum advance?? 1984camaroZ28 Engine 1 10-12-2002 02:57 PM
