Nova brake pad question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2007, 04:45 PM
I have been rebuilding the front end of my 1970 nova. I bought the thing as a bare shell and am slowly working my way around it. It had disc brakes and i got new rotors and pads to put on. My problem is that the outer pad for each caliper just doesn't stay put. It has these tiny little tabs that wont bend over the outer caliper ears and it flops/slides back and forth on the bolts and against the rotor easily. First I got autzone duralast pads and when this happened returned them and bought raybestos pads from another dealer but the situation is the same either way. What do I do here? the inner pad easily clips on with the little piece that snaps into the piston, but the outer pad moves all over and scrapes against the rotor!
Old 05-09-2007, 04:56 PM
Jmark's Avatar
Set the outer pad on the floor so it's standing up on the inner edge of the metal part of the pad and gently hit each tang with a hammer, (bending them over more) test fit, hit again, test fit. Do this until the outer pads go into the caliper with a little pressure. ALL brands are like this. Sometimes you can just install out of the box but if the rotor is out even a little, the pad will give you a click, click, click as the rotor moves the pad up and then lets go. Just mash em over a tad! LOL
Mark
Old 05-09-2007, 08:32 PM
The Factory Service Manuals actually show a process of using a larger channellock pliers to squeeze the tabs in place around the caliper body. I've never been able to get them tight enough that way, so I use Mark's method of mashing them with a hammer before installing the pad in the caliper. All GM single piston calipers are designed this way.
Old 05-09-2007, 08:39 PM
Mark
Sounds simple enough, tap it with a hammer.
Just to clarify, how should I set the pad on the floor?
Old 05-10-2007, 04:56 PM
Jmark's Avatar
Stand the outer pad on the concrete floor or good vise so it's resting on the metal part of the pad and the two "tangs" are on top. The channel locks works too but as stated, it's hard to get them snug enough doing it with the pads installed in the caliper.
71 Nova mono to multi leaf question. 1971 Nova Suspension - Brakes - Steering 5 12-05-2008 10:11 PM
72 Nova Front Disc Brake Conversion Help leejoy Suspension - Brakes - Steering 7 05-01-2007 11:29 PM
Rear Disc Brake Pad Replacement ccarccrazy Suspension - Brakes - Steering 3 01-13-2007 07:59 PM
Ford wide five brake drum question Red 49'er Suspension - Brakes - Steering 1 03-21-2006 04:51 AM
Uneve Brake pad wear on 2001 Malibu Malibucdl Suspension - Brakes - Steering 17 04-09-2004 10:13 AM
