-   -   Nova and camaro sub frame same? (http://www.hotrodders.com/forum/nova-camaro-sub-frame-same-12534.html)
Pro1972nova 01-26-2003 02:53 PM
I want to buy a camaro 67-69 subframe will it bolt and work like a factory frame like on the 72 nova now.
pasadenahotrod 01-27-2003 10:46 PM
Why do you want to do this? Find a 73 or 74 Nova with disc brakes, power steering and whatever else you want and use it! First of all, the Nova clip(find a 4door Deluxe) will probably be cheaper than the Camaro (it's in the name, you see...), secondly, you have a NOVA!
F-1Rodder 01-28-2003 09:24 AM
The '67-'69 Camaro is a front steer unit. Is the Nova front steer in '72? It is easier to work with a front steer in most rods.
You don't say what application you are using the clip in, but that particular clip is pretty wide for most pre-'50's cars.
[ January 28, 2003: Message edited by: F-1Rodder ]</p>
