Nova chassis - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2003, 06:30 PM
Post Nova chassis
how much hp and torque can I throw at a stock 74 nova chassis without upgrading? what would I upgrade first?
Old 01-17-2003, 07:19 PM
BOBCRMAN@aol.com's Avatar
Post
as novas are the same basic car from 68 on, i'll tell you a little story. I bought a COPO 70 Nova new Jan 1970, ran it bone stock till the snows melted in the spring, changed the intake and carb, installed headers, bought some 10" slicks and took it to the drags, ran fine no problems. I then removed the 402 and replaced it with a built LS-6 454 engine, 4.33 gears,traction bars and 11" slicks, made three passes at a good traction strip and the body cracked in the roofline where the quarter is welded and leaded to the roof, also where the quarter and door post meet, the spring perch started to tear from the rear end also, ended up using solid aluminum body mounts and a welded subframe connecter, this makes a much stiffer setup and things no longer cracked or twisted.
Old 01-18-2003, 06:07 AM
Post
what kind of hp was your 454 putting out?
Old 01-18-2003, 01:54 PM
Post
no idea, the car was daily street driven, used to change the tires and drop the exhaust, go racing the car was a consistant 11.70's went 11.67 twice. weighed 3205 on dragstrip scales.
Old 01-19-2003, 12:07 PM
Post
thanks, that's a bit faster than I'm looking to go. How much do traction bars help? Are they only necessary on a very powerful car? I have a mild 350 in it
Old 01-20-2003, 06:22 PM
Post
without traction bars your nova will wheel hop.
