Nova disc brake question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2006, 10:27 AM
I recently got a 1970 Nova to work on. The car came with it's original dealer sheet that does not indicate it came with front disc brakes, however the car does have them so I am assuming an aftermarket kit was used or the pieces were taken from a car that did. THere are no lines attaching anything up front, and I am wondering If i am missing anything, like a proportioning valve? Basicly there is a rectangular box with a few ports in it that sits under the master cylinder...if i were to hooke lines up would everything work?
Old 08-04-2006, 12:10 PM
poncho62's Avatar
Wiki Edits: 5
That doesn't sound like a proportioning valve, a pic would help. Front disks/rear drums requires one........
Ontario Rodders
Old 08-04-2006, 12:46 PM
CDJr's Avatar
Experienced Amateur
Last wiki edit: Automobile body and frame rotisserie
Wiki Edits: 2
I think what you have there is a combination valve/distribution block (if memory serves me correctly from when I took apart my '74), which may or may not work if discs have been added. It wouldnt hurt to try it out, but you may need to get a new one anyways like poncho said. Are you sure those arent original discs?
Old 08-04-2006, 01:50 PM
DOUBLEDICK's Avatar
the block under the master is a proportioning valve. if it is the right one for your disk brakes it will have 2 lines that come down from the master to the side of the block then it should have 2 places for front brake lines in the front and one on the back for the rear brakes.I have included a couple pictures to help you.I have a line lock and a pressure switch for the brake lights on the line from the master to the block for the front brakes, yours will not it will be a regular brake line.If you have any other questions you can email me directly and I will answer them. Good luck and enjoy your Nova
Name:	102_1244 (600 x 450).jpg
ID:	13890   Click image for larger version
Name:	102_1245 (600 x 450).jpg
Old 08-04-2006, 09:24 PM
Some of the proportioning valves were cast iron instead of brass, but they're about the same size. Drum-brake cars used a smaller valve assembly.
Old 08-04-2006, 11:52 PM
Perfectionist Procrastinator
Last journal entry: Moving along
My 70 Nova had disc brakes from the factory, as far as I know, so I went out and took a couple of pictures. Like has been said, it has two lines coming down from the master cylinder into the proportioning block/valve, two lines going to the front disc brakes and one line going to the rear drums.
Hopefully you can compare these pictures to what you have. The big rusty thing in the top of the pictures is the master cylinder.
Pic 1: Front
Pic 2: Left (driver) side
Pic 3: Right (passenger) side
Hope this helps.
ID:	13904   Click image for larger version
ID:	13905   Click image for larger version
63 impala front disc brake conversion derwood3 Suspension - Brakes - Steering 6 12-27-2012 05:04 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 09:06 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
early nova disk brake conversion hotrod66_57 Suspension - Brakes - Steering 2 04-29-2005 01:55 AM
Nova disc brake conversion CombatWombat Suspension - Brakes - Steering 2 07-07-2003 03:15 AM
