The disk/drum M/C has different valving than the drum/drum........I would imagine the proportioning valve is different also.
Ontario Rodders |
I asked the guys at Scarebird about this and thay said drum drum master would be ok. Thats what I have on mine now and it works fine. They said that I wasn't pleased with the stopping power to switch to a disk drum master and proportioning valve.
I did something similar years ago when I converted my 69 Camaro to front disks. I did not initially use a MC for disk brakes. It stopped OK, a little better than drums, but not what I expected disks to do. The original MC went south so I opted for a Corvette MC with front disks and rear drums, along with the proper proportioning valving. The difference was night and day, all of a sudden my Camaro had vastly improved braking.
Vince |
Drum brake master cyls generally have a non return valve behind the brass cone in the m/c outlet. If you convert from drum to disc on either or both axles you must lose this valve (spring and split rubber cup.)
Disconnect the appropriate brake line, screw a self tapper into the cone and using a pair of side cutters pry it out. discard the valve, refit the cone and bleed brakes. The valve is only there to maintain fluid at the wheel/cyls - calipers don't have return springs. |
| nova front clip | beetle9 | Suspension - Brakes - Steering | 5 | 09-20-2004 01:08 AM |
| Dual master cylinder for drum/disc brakes | wiretwister | Suspension - Brakes - Steering | 4 | 02-16-2003 08:56 AM |
| Somebody stop me!!!! | Mrfixmaster | Suspension - Brakes - Steering | 35 | 01-29-2003 06:45 AM |
| 1963 Nova Front Suspension | Dan McClintock | Suspension - Brakes - Steering | 0 | 10-21-2002 01:15 PM |
| Stang master cylinder | Old Crow | Suspension - Brakes - Steering | 3 | 06-10-2002 12:40 PM |
