Nova Fender problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2009, 03:43 PM
1972's Avatar
I am trying to put the fenders back on my 72 nova but I'm having 2 problems, my first problem is that on the bottom of the fender there is a square notch from the fender where it looks like a clip of some sort would go to bolt up to the rest of the body, It has been to long since I have taken these fenders off to remember exactly how to put them back on. Has anyone run into this or have some sort of a solution? I can post pictures a bit later if that will help. My other problem is getting the fenders aligned just right but i think this is mainly due to my other problem. Thanks!
Old 06-09-2009, 05:08 PM
ericnova72's Avatar
More for Less Racer
Front bottom edge where it connects to the core support(about 6" up on the inside of the fender), front bottom edge where the fender brace rod bolts to(very bottom edge), or rear bottom edge between tire and door(two u-shaped or two 1-1/8" square cut-outs)?
Old 06-10-2009, 07:40 AM
1972's Avatar
Yes and thanks for the responce, I actually got it figured out last night. I think I had just spent too much time under the hood for the day before and couldnt realize the obvious.
Old 06-10-2009, 08:33 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Dang, they sure don't call you "ericnova"72 for nothing!!
OT, that's a good problem to have- aligning the sheetmetal on a 1972 Nova- the '68-'72 Nova is one of my favorite street machines...
I need to paint a fender onl. Help! Riot Racing Body - Exterior 6 11-08-2007 11:53 AM
Gap problems fender to door when front fascia installed Ripped Body - Exterior 25 03-19-2006 08:15 PM
trying to identify a chevy fender i found recently fast68 Body - Exterior 2 11-26-2005 03:53 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 02:43 AM
