nova leaf springs 79 to 68 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2010, 06:03 PM
will 79 spring fit a 68
the 68 is mono the 79 is 6 leaf
Old 06-05-2010, 06:25 PM
ericnova72's Avatar
More for Less Racer
Spring is the same size, but the rate might be different.
The Mono spring perch on the axle housing is not deep enough for the multi leaf spring but can be made to work, you will need longer U-bolts and may want to fab up some spacer sleeves to fit around a short section of the U-bolt inside the perch area, to keep from bending the bottom retainer plate and the U-bolts coming loose. Be a good time to add a GOOD traction bar like CalTracs or Competition Engineering slapper bars, they both have a real solid lower spring plate.
You could also remove the mono perches on the housing and replace with multi perches, this will require cutting and welding, Check with resto suppliers or Moser or Randy's Ring and Pinion to get them.
What rear axle do you have in the '68?? 10-bolt?(8.2" or 8.5"), 12-bolt??
Rear Leaf Springs ...."Clamping Them?" white66coupe Suspension - Brakes - Steering 12 03-11-2006 12:04 PM
Better leaf springs or 4 link? whytry Suspension - Brakes - Steering 25 09-02-2003 05:34 PM
Converting coil springs to leaf on a 9" BillyBob1950 Transmission - Rearend 9 04-25-2003 04:27 PM
moving nova springs inboard La Maquina Transmission - Rearend 1 04-09-2003 05:54 PM
leaf springs ffcagle34 Suspension - Brakes - Steering 4 12-18-2002 06:49 PM
