Nova leaf springs used on a nine inch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2011, 09:42 PM
I have a 71 nova with a 10 bolt in it with the factory leaf springs and I have nine inch rearend that is the correct width for the nova but has no springs does anyone know if the chevy leaf springs will work?
Old 12-01-2011, 03:50 AM
SSedan64's Avatar
I answered this in your other Post also.
Yes, if the 9" has the correct Spring mounting Pads it will work.
You could remove them from the 10-Bolt Tubes & mount them on the 9" Tubes if the Axle Tubes are the same Dia./size. If not you may be able to grind the Pad's radius larger or you can buy new Mounting Pad fairly cheap.
The 8.5" 10-Bolt Rear is a strong Rear, only difference between it & the 8.875" 12-Bolt is the Ring gear size.
Old 12-01-2011, 04:42 AM
Thanks
Thanks for help, I have a 71 nova two door that has a nine inch posi with 3.70 or so gear and the springs are two long and will have to weld new hangers. I just got a 70 nova 4 door parts car that has a 10 bolt and I thought it would be easier if I could change over the leafs instead of welding the hangers.
Nova leaf springs used on a nine inch? 71novafreak Suspension - Brakes - Steering 1 12-01-2011 02:40 AM
nova leaf springs 79 to 68 rmccolery Suspension - Brakes - Steering 1 06-05-2010 06:25 PM
1967 Nova leaf springs boobert Hotrodding Basics 20 12-30-2006 10:31 PM
leaf springs for a 66 nova.... sc2dave Suspension - Brakes - Steering 12 12-29-2006 10:51 PM
72 nova leaf springs joesnova2 Transmission - Rearend 7 06-09-2006 09:12 PM
