Nova manual steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2005, 10:01 AM
Fil's Avatar
Fil Fil is offline
What will bolt right up to my 1972 Chevy Nova when I go to my local yard? Which vehicle could I get a quick ratio steering box that will fit? What other parts should I also take to make it a complete swap? I currently have a power steering box without it being hooked up. This is the way the car came.
Old 04-08-2005, 11:22 AM
astroracer's Avatar
The Nova's and Camaro's are the same. A Z/28 box will bolt on but good luck finding one in a 'yard. Go here...
http://www.carparts.com/servlets/Web...C=jcw-carparts
Cross-referencing parts is easy, just compare the pt.no's as you look them up for different vehicles.
A base and V8 optioned Nove uses the same slow strg box. The base Camaro uses the same box as the Nova but the Z is optioned with a quick ratio box, 2 1/2 -3 turns.
Mark
Old 04-08-2005, 01:21 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Ig all else fails
Go to This place and you can get the steering box that fits..I think but not sure the manual box is a one to one fit so there is only changing the box to concern yourself with..
OMT
Old 04-08-2005, 09:41 PM
A manual box from a '68-'81 Nova or Camaro (and clones) will fit. The manual gear requires a different pitman arm because the output shaft is smaller in diameter. Get the longest one you can find for a '69 Camaro, because the faster steering ratios were partially made with longer pitman arms & shorter steering arms. Short steering arms could be found on many power-steering cars, so yours might already have the short ones.
Here's a good site for first-gen Camaro suspension & steering info. The '68-'74 Novas use the same front end as those cars, so it might help you find what you want. http://ourworld.compuserve.com/homep...eering_linkage
Might also search around at the classified section at www.camaros.net, a site that specializes in first-gen Camaros.
The rag joint may be different between power & manual. I changed mine from power to manual, but the joint on my junkyard '75 Firebird P/S box was still good, and it bolted up fine.
Old 04-09-2005, 09:58 AM
Fil's Avatar
Fil Fil is offline
Thanks everyone for all your help.
Switching to Manual Steering skeeveman Suspension - Brakes - Steering 2 01-28-2005 11:23 AM
Manual Steering Box sb72elcamino350 Suspension - Brakes - Steering 1 01-29-2004 11:07 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
Nova Steering novachad Suspension - Brakes - Steering 2 04-01-2003 07:58 PM
really slow manual steering Steve karch Suspension - Brakes - Steering 8 05-03-2002 09:06 PM
