nova motor mount interchange - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2006, 04:22 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
I was wondering if 1973 74 etc motor mounts (frame and block halves) will fit into a 1972 nova? I heard these are better as they are "clam shell" and interlocking so if one breaks...well you can still get home.
Basically I just took a 250 out of 1972 nova, have 1975 350, and I need block and frame mounts as the 1975 mounts do not line up with existing holes
Also when did HEI distributers come into service?
Thanks
Old 08-16-2006, 10:24 AM
Warrant's Avatar
AHHH! ok local auto parts stores sell the block halves...but I cant find any frame mounts....nvm I got it undercontrol
Old 08-17-2006, 12:44 AM
With the later-type clamshell mounts, the parts stores actually sell the rubber-and-metal bottom parts, and the steel engine brackets are the hard-to-find parts. Lots of them can use the same ones, but I don't know about the '73-'74 Novas. Up until recently GM sold engine brackets for '75-'79 Novas that were also listed for late-'70s Impalas, but those Novas used a totally different subframe from yours.
Might post over at www.stevesnovasite.com/forums and see if anybody over there knows what you need. They refer to '68-'74 Novas as "third-generation", in case you run into any confusion.
Old 08-17-2006, 03:47 AM
poncho62's Avatar
Wiki Edits: 5
The HEI became standard equipment in 1975.
1968 Nova SS is about to end its Life Seagroves Hotrodders' Lounge 50 10-20-2009 06:04 PM
Help NOVA straight axle What~ th375Bmark Suspension - Brakes - Steering 2 01-23-2009 11:04 AM
75 Nova differential interchange? binder56jd Transmission - Rearend 5 12-20-2005 09:39 PM
63 Nova Front & Rear Seats Mustangsaly Interior 3 10-13-2005 09:44 AM
63 nova discs jtdchevy Suspension - Brakes - Steering 6 05-11-2004 11:35 AM
