Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Nova is painted !! Pics !! :-)
  #17 (permalink)
Old 09-16-2012, 04:30 PM
novafreek6872's Avatar
novafreek6872 novafreek6872 is offline
Nova Guru
Originally Posted by Polish Painter View Post
Very nice, Tell be about your cut and buff process. What grit papers and blocks did you use ??
Sure...try this out, I think you'll like it.
2000 wet on a "glazing block" to knock the "peel" down don't be stingy with the paper, when it dont cut, toss it, , Then Meguiars "Ultimate Compound" and a Yellow buffing pad... Very fast AND effective... and I've tried many different buffing compounds and this one ROCKS.
If you are super anal about swirls, you will want to follow up with a swirl remover and polishing pad. I didn't do mine yet because I havent had time for that step. It looks good with just the process I mentioned above.
