Nova Power Steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2007, 04:28 PM
crusherdbuzz's Avatar
71 Chevrolet Nova
Nova Power Steering
I currently own a 71 nova with manual steering. I found a person that is piecing out a 73 nova with power steering. To convert mine I only need the pump, pump bracket, power steering box, and the hoses correct? I can reuse my steering column etc. It should be a bolt on replacement?
Regards,
Dennis
Old 02-17-2007, 06:08 PM
I may be wrong ... but I believe the boxes are different ... a 71 is rear steer and I think a 73 is front steer.
Old 02-17-2007, 08:30 PM
71 Chevrolet Nova
He has the entire steering system for the car. I was just curious what I need because I don't want to purchase things I don't need. I did a complete front suspension/steering overhaul a year ago to the car.
Old 02-17-2007, 08:36 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
If what Deuce just told you is correct...The steering box will not work on your car. Best to make sure before you buy it.
Old 02-17-2007, 11:22 PM
powerrodsmike's Avatar
Wiki Edits: 161
Classic industries lists the same part number power steering box for 68 through 76 nova.
Check it out HERE
I will look in my Durex catalog tomorrow to verify. That catalog will say if it is standard or reverse rotation. If it is the same power box then it should bolt right in in place of your manual box.
Later, mikey
BE different....ACT normal.
Old 02-18-2007, 09:52 AM
Originally Posted by Deuce
I may be wrong ...
I'm afraid you are
Nope. 68-74 are rear steer (same hardware as the first gen F-body) and 75-79 are front steer (same hardware as second gen F-body). Having said that, the Saginaw power steering boxes on those cars are all the same. It's the pitman arms that are different.
Old 02-18-2007, 09:56 AM
71 Chevrolet Nova
So, I can reuse my old pitman arm or the one on the power steering box correct? All i need is the pump, pump bracket, hoses, belt and the box?
I appreciate the responses guys.
Old 02-18-2007, 11:37 AM
Originally Posted by joe_padavano
I'm afraid you are
OK ... I was wrong ... happens every now and then ...
I knew that the later ones were front steer and thought the change came when the body changed in 73 ...
The question had been viewed over 20 times with no response ... so at least I got it up top where he could get a few more views and the correct answer.
Deuce ... Moderator
Old 02-18-2007, 12:04 PM
What's the old line? I made a mistake once. I thought I was wrong. (BADDA BING)
Actually, the steering change DID come when the body changed - in 1975. The 68-74 Novas all use a subframe that's based on the 67-69 Camaro subframe. The 75-79 cars use a subframe based on the 70-81 Camaro.
Old 02-27-2007, 01:48 AM
You definitely need a pitman arm, since manual & power arms don't interchange. Also, look at your pulley & belt setup vs. the '73. I converted my '72 Nova (350, factory air) from manual to power, and I just had to add a belt. I used the coupler that was already on the power steering gear, and it bolted up to my original steering column. My P/S gear came from a '75 Firebird, while the pump setup came from a '75 or '76 Monte Carlo.
If you want to quicken the steering, get the steering arms from the P/S car. They should be shorter than yours, and that gives you more turning angle from the same steering wheel movement.
weird power steering gothrod87 Suspension - Brakes - Steering 3 06-15-2005 08:42 AM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
Power Steering Hose Connections Larry D Suspension - Brakes - Steering 3 12-02-2003 07:06 AM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
Nova Steering novachad Suspension - Brakes - Steering 2 04-01-2003 06:58 PM
