Nova Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2006, 05:53 PM
mkn mkn is offline
Nova Rear End
I Have A Cance To Get A Rea End Out Of A 1974 Blazer K-5 It Measures 60"from Drum To Drum And 52 1/2"from Back Plate To Back Plate.is This Going To Work? Thanks
Old 09-22-2006, 06:08 PM
TroyBoy's Avatar
Psychomotors
whats your reason for wanting -this- rearend?
Old 09-22-2006, 06:31 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Is this going to work for ...what???
Old 09-22-2006, 06:33 PM
TroyBoy's Avatar
Psychomotors
I've got a 70 Nova .My car is buried in my garage,but your measurements sound about right .Is it a 12 bolt?You'll have to redrill lug pattern,pinion gear shaft is not as thick a diameter as a 10- 8.5 or 12 bolt car rear end .Just went out and measured my extra 8.5 10 bolt .It measures 54 1/2 "inside hub to hub. My 76 Blazer mud buggy 12 bolt measures 56 1/2" inside hub to hub.Are you sure of your measurements? What kinda car and what you wanna do with it?
Old 09-22-2006, 08:11 PM
Rearend for my 63 nova ss
Hey gang - I would like your opinions! I have a stock open hotchkiss rearend in my nova, with a 194cid 120hp motor with Powerglide. I am putting in this winter, a hopefully 300hp or so 250cid motor with 700R4. Would it be do-able to posi my hotchkiss rearend, or go with a 9" Ford cut to size?? Any other thoughts?? NovaBoy
Old 09-22-2006, 08:22 PM
Lost in the 60's
Wiki Edits: 4
My only thought is why do you want a 6 cyl.? when you could have a V-8
Old 09-23-2006, 06:31 AM
mkn mkn is offline
Nova Rear End
I Have A 64 Nova With A Non Posi. Rear End .it Has A 350/325 With A 350 Trans.the Width Seems To Be The Problem
Old 09-23-2006, 07:07 AM
The Nova rear end in the 62-63 cars has the same center as the 55-64 chevy rear end. You can get the posi units at several places. The carrier break is at 3.70 on most units:
http://www.jawsgear.com/store/catalo...ath=31_188_214
Old 09-23-2006, 04:17 PM
Why 6 over 8 cylinders?
Hi there Henry Highrise! Because there is always a v8 in almost all Novas! I want something different! About 19 yrs ago I built a 250 six and had it in a 78 Camaro. I had the pleasure to dust off some 350's and a couple of mild 327's. this motor will have a bit more heat to it. After a short period of running the new motor, I will probably be attaching a centifugal supercharger to the engine, with about 5 or so pounds of boost! There are some guys out there who are playing with this stuff and having great success! I hav a book right now where a guy was getting 400+ hp with 6 to 8 pounds of boost! I really apreciate your question!
Old 09-24-2006, 06:02 PM
TroyBoy's Avatar
Psychomotors
Hey guys,my buddy had a 65 Chevy II wagon and he used a 60's Bronco 9",it was an inch or two narrower than your original rearend-lotsa parts available
Old 09-27-2006, 08:31 AM
Thanks for the info
Hey Troyboy- Thank you for the info. I am going to check with a guy who rebuilds old Broncos and see if he has anything. Thanks again! NovaBoy
Old 09-27-2006, 03:04 PM
TroyBoy's Avatar
Psychomotors
Good luck,I think he even was able to use a chevy u-joint also
66 nova rear end robbysapien Transmission - Rearend 5 08-01-2007 07:48 PM
Nova Rear End - Wide Tires Delirious2000 Transmission - Rearend 3 07-06-2006 02:48 PM
will nova rear end fit in 67 firebird? red_rider52 Transmission - Rearend 9 01-19-2005 10:52 PM
64 nova rear end width risaacp Transmission - Rearend 2 05-05-2004 12:03 PM
70 nova rear end 355'swhat no.splines oldnable Transmission - Rearend 5 07-18-2002 11:39 AM
