Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Nova Rear End - Wide Tires
Old 07-06-2006, 01:38 PM
rj57's Avatar
rj57 rj57 is offline
I can post a link to a tire calculator if your interested?
You plug in the numbers you know and it will help you determine wheels/tires you can run.
This was set up for '55/6/7 Chevies, but as long as you know the width of the frame rails, the leaf springs, and how far apart your quarter panelsare you should be able to use this?
