This is the Introduction forum.....you need to post that question over in the Suspension forum. That way the guys with the answers will see it.
moving it...but a 71 Nova doesn't have struts
Ontario Rodders |
Those cars have a bolt in front subframe which holds your front suspension, engine, trans etc. If that sub frame is weak, the whole unit can be replaced. Are you saying that parts of the sub is weak or rusted........or are you wanting to beef it up as a performance upgrade...like adding a roll cage etc?
Ontario Rodders |
as Poncho said, the sub frame structure is already pretty beefy. The only improvement you could possibly make is a tube roll cage that ties into the sub frame. Other than that replace the entire sub frame assembly with an aftermarket sub frame. Several firms make sub frame replacements for Nova's and Camaro's.
Vince |
Like Poncho and Vince said, the stock sub-frame is plenty stout. One reason for going to an aftermarket sub-frame is to shave weight off the car. I would start with a set of sub-frame connectors. Most don't require anything more than a little common sense and bolting skills. If you need more stiffness, go to a 6 point bar or a cage.
I am really wondering why you are asking. Are the body tub mount locations for the sub-frame rusted out? |
I don't have any rust problems or anything like that. I'm just looking into every possible way to stiffen it up without a roll cage. I have looked into subframe connectors a little bit. Are there any companies that you would recommend over others? Right now I'm looking at a set from competition engineering. thanks for the help
CE build a quality product, but I believe they are weld in. Not sure which are good on the bolt-in type. |
Did I mention body mounts, AKA sub-frame bushings? New rubber ones are far better than what's typically left of 35-year-old originals, and urethane ones are even stiffer, but ride quality does suffer a bit.
| Grand Am Strut Replacement - Help | leejoy | Suspension - Brakes - Steering | 12 | 08-30-2007 11:59 AM |
| modifying a fwd cars strut tower for turbo clearnce - advice needed | lowROLLERchevy | General Rodding Tech | 4 | 03-10-2006 11:20 PM |
| strut bar for a 66 nova? | sc2dave | Suspension - Brakes - Steering | 1 | 09-15-2004 07:20 PM |
| Shock tower removal on 66 Nova, help! | frankenvette | Suspension - Brakes - Steering | 2 | 07-06-2004 05:48 AM |
| '62 Nova to late F-body strut conversion | Jones | Suspension - Brakes - Steering | 1 | 10-02-2001 10:55 AM |
