nova subframe - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2011, 07:01 PM
nova subframe
hi i have a 72 nova i need 2 replace my subframe and i found a 72 firebird subframe does anyone know if it will fit
Old 07-03-2011, 06:06 AM
BOBCRMAN@aol.com's Avatar
NO, the Camaro-Firebird sub was re-designed in 1970 and is not compatible with 68-72 Nova.
Old 07-03-2011, 03:47 PM
ok thank you i thouught i heard at 1 point that the bumper whole just need to be re drill
Old 07-03-2011, 04:45 PM
The 68-74 Nova and the 67-69 Camaro/Firebird are similar and have the steering linkage BEHIND the crossmember (called rear steer). The 70-81 Camaro/Firebird and 75-79 Nova have the steering linkage in FRONT of the crossmember (called, surprisingly enough, front steer).
Old 07-03-2011, 05:43 PM
ok the guy says that everything is there so i was just hoping it would work the disc brakes are there and everything and he only wants 200 for it
72 camaro subframe in my 72 nova 396nova Suspension - Brakes - Steering 4 07-09-2011 04:58 AM
rambler with nova subframe 396Wheelstand Suspension - Brakes - Steering 28 12-22-2009 03:27 PM
nova subframe dimensions switchblade51 Suspension - Brakes - Steering 2 06-02-2009 04:09 PM
68-72 Nova subframe to 49 Chevy P/U ronbo78 Suspension - Brakes - Steering 4 11-02-2008 09:59 PM
nova subframe on a 59 chevy truck bet on black Suspension - Brakes - Steering 3 01-27-2005 08:48 PM
