nova subframe on a 59 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2005, 12:55 PM
bet on black's Avatar
hotrodder 4 life
i am in the process of restoring a 59 chevy 1-ton pickup and i have some questions about an IFS swap.
i have a 77 nova for a donor car that i wanted to use the front subframe on the truck. the framerails and track width are the same as the truck. i don't plan to keep the 1-ton payload, but i would like to be able to tow a 5000 lb. boat trailer with it. my concern is that the front suspension may not be strong enough for the added weight of a long bed truck. i plan to upgrade the brakes and rebuilt the suspension.
is the nova front suspension strong enough to hold up a long bed truck? would it be unsafe to tow with it?
Old 01-27-2005, 01:14 PM
poncho62's Avatar
Wiki Edits: 5
I put a Nova subframe under my 51 Ford, and towed my 3800 lb house trailer all over the country.......I don't see where you would have a problem..
Ontario Rodders
Old 01-27-2005, 03:55 PM
hotrodder 4 life
did you change the springs?
i want stiffer springs, but don't want to lower the truck any more than the subframe will at its stock height.
Old 01-27-2005, 08:48 PM
poncho62's Avatar
Wiki Edits: 5
No...didn't change springs..it's all stock.
Ontario Rodders
