nova suspension problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2004, 12:48 PM
New Member
I have a 71 nova with some suspension problems. The car sags down in the passenger rear quite a bit, also on the traction bars the driver side bar does not touch by about 1 inch, but the passenger side traction bar either touches or is about 1/8 inch of touching. Does anyone know what the problem would most likely be.
Old 03-12-2004, 01:58 PM
BOBCRMAN@aol.com's Avatar
Weak or broken spring.
Old 03-12-2004, 05:36 PM
poncho62's Avatar
Wiki Edits: 5
Check the frame where the springs mount. These cars are bad for rusting in this area.......Hopefully, it's just a bad spring.
