novice removing door handle?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2005, 08:13 PM
need to change out interior door panel 74 pontiac.. does the handle just pull straight out to get off?
Old 11-05-2005, 08:37 PM
poncho62's Avatar
Wiki Edits: 5
The window crank has a wire "C" clip ....you pry the handle away from the panel a bit and you will see it. There is a special tool, but a bent screwdriver will work too.
Old 11-05-2005, 10:25 PM
MI2600's Avatar
Member# 3287
You can buy inexpensive handle removers at most parts stores. Essentially they slide in along both sides of the stud that the handle mounts on and forces the wire c-clip out. Worth the few bucks. Or, as Poncho said, you can use a slender screwdriver and try to get at the ends of the clips. It works, but it's a little more taxing on your frustration level.
Old 11-05-2005, 11:49 PM
Here is the correct tool.......only a few dollars at most parts stores...this one is a Snap-On ...........but the cheap ones work great too......
DEUCE....
Old 11-06-2005, 06:11 PM
thanks alot everyone!
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 04:18 PM
removing torque converter darom Transmission - Rearend 2 06-14-2004 03:53 PM
removing camaro engine by removing sub-frame bullheimer General Rodding Tech 7 04-23-2004 03:46 PM
removing bumper 1964 Impala matt_ramsey Body - Exterior 7 06-24-2003 03:15 AM
need help, removing ac system on 91 mustng jfmustang General Rodding Tech 1 04-19-2003 05:20 AM
