Now I知 confused, Nason Ful-Thane 2K single stage - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2005, 07:54 AM
Scode68's Avatar
Ed S.
I just got myself all confused and need some clarification. Nason Ful-Thane 2K Urethane is a single stage finish but it says 2K in the title, is it just a single stage? Do I have to shoot a clear over it if I知 using a metallic color? The last question is if I use a siphon gun, what tip size and psi works well with it. The tech sheet says 60-80 psi with no tip size. Does this sound high for the psi at the gun?
Old 05-25-2005, 11:11 AM
Have Gun, Will Paint
2K refers to the paint needing hardner, and yes it's a single stage with no top clear coat needed.
As for the gun......the psi rating could be right it it's a standerd gun and not a HVLP type.
You tip size should be 1.4 or 1.5
Old 05-27-2005, 05:43 AM
Scode68's Avatar
Ed S.
Thanks!
How about on a HVLP? I知 currently searching for one that will work properly with my compressor. I see that Sharpe pretty much recommends 1.5-1.6 for a DuPont single stage urethane.
Old 05-27-2005, 10:39 AM
I would go with a 1.4 or 1.5, but no bigger then that.
single stage vs. base clear? CAMARO Body - Exterior 38 01-30-2009 11:03 AM
Single stage and duel stage air compressor? DeathByGreaser Body - Exterior 24 10-19-2005 06:33 PM
Nason 2k primer oldred Body - Exterior 1 04-18-2005 09:15 PM
Sanding single stage? Project87c10 Body - Exterior 6 11-05-2004 12:44 PM
bc/cc over single stage? Lay'nFrame Body - Exterior 1 06-04-2003 01:56 PM
