-   -   Now what ? (http://www.hotrodders.com/forum/now-what-231851.html)
DrBee 04-14-2013 10:20 PM
Now what ?
Plenty of brake pedal until I start the engine, then it goes almost to the floor. Power brakes with a single diaphram booster (new), new master cylinder, and new hoses. Disc front/drum rear. The vacuum hose is currently hooked to the port on the back of the carb.
RWENUTS 04-15-2013 09:07 AM
What's your pedal ratio?
Did you drill a new hole in the brake pedal arm 1 1/2 inches below the stock hole?
DrBee 04-17-2013 06:30 PM
Now What ?
I don't think pedal ratio is the problem. The have been working fine, then all of a sudden the problem appeared. I have the proper Proportioning valve and residual valves.
