NP203 speedometer gear problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 10:05 PM
i have recently rebuilt the motor and transmission is recently rebuilt also. The problem here is that the speedometer does not work. I have replaced the gear and key also i hooked a drill up to the cable and spun it and the gauge worked so i know its in the trasfer case.. Im not sure if there is a gear that is not messing in the transfer case? Also if i need to replace this gear can i get to it by unbolting the rear output part or do i need to take the whole transfer case apart?
Any info would be awsome..im at a lost!!
thanks,
Mike Miller
Old 02-01-2009, 11:15 PM
Wiki Edits: 85
All you need to do to get to the drive gear is to remove the one or both aluminum housings for the rear output. Be careful, the shaft & other parts could fall out. There should be a colored gear on the shaft.
Due to forum rules I cannot post a link with further information.
Old 02-02-2009, 07:08 AM
that is awsome info thanks. i have one last question..once i get that output housing off does that colored gear slide off or do i need to take the whole shaft out?
Thanks,
Mike
Old 02-02-2009, 11:30 PM
Wiki Edits: 85
Slides off. Don't remember whether it is retained by a snap ring or not.
Old 02-03-2009, 12:05 PM
thank you for your help mmerlinn there is little information on this and i didnt want to get to involved with it without knowing what i was doing..
Thanks again,
Mike
Speedometer & odometer problem Ron Marciano General Rodding Tech 1 10-16-2007 04:39 PM
Muncie speedometer gear GMR Transmission - Rearend 14 10-15-2007 08:18 PM
GEAR DRIVE = DAMPER PROBLEM bullheimer Engine 5 07-06-2006 12:09 PM
Speedometer Problem downgenocide General Rodding Tech 1 07-15-2005 02:18 AM
Roller cam/distributor gear information Jmark Engine 0 12-29-2003 03:56 PM
