np205 to th400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2007, 08:46 AM
np205 to th400
wondering if a np205 on a chevy th400 will bolt up to a gm th400?
Old 09-02-2007, 09:41 AM
I would hope so they are both the same trans....
Old 09-02-2007, 09:57 AM
Last journal entry: A Little Farther Along
turbo 400 to 205
with all the 400 floating around out there you have to check output shaft diameter and spline count because there are different output shafts used on the 400 and different input shafts used on the transfer case
Old 09-02-2007, 01:20 PM
repost to 400/np205-700r4
Guy just called me and the np205 is connected to a 700R4 not a 400. So it would be comeing off the 700r4 and going on the gm th400.
Old 09-02-2007, 03:37 PM
the guy i am buying the transfercase from just called and said the trans is a 700r4. So i guess my question now is would a np205 on a 700r4 bolt to a gm th400?
Old 09-02-2007, 06:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the t-400 output shaft will not fit the t-case for the 700r4 trans.
GM built 3 different length outputs for a 4x4 application of the t-400.
ALL of them are the same diameter size and 32 spline count.
there are shafts for the :
203 t-case
208 & late 205 t-case
early 205 t-case.. this output shaft is the SAME as the short shaft commonly used in 2 WD applications
At one time Advance Adapters sold an output shaft for the t-400 that was machined with 27 splines like the t-700 has. I do not know IF this shaft is still available or NOT.
I have seen many of these machined down t-400 output shafts broken.
T-400 clutch drums joe_padavano Transmission - Rearend 9 06-18-2007 12:02 AM
TH400 to 4L60e 1939P7 Transmission - Rearend 7 12-22-2005 08:18 PM
TH400 power handling and RPM range Philly Single Transmission - Rearend 3 09-28-2003 05:51 PM
67 firebird th400 info speedfrk3 Transmission - Rearend 2 12-10-2002 06:31 PM
TH400 in firebird v/s TH400 in bonniville help speedfrk3 Transmission - Rearend 11 11-04-2002 12:19 PM
