np208 transfercase - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2009, 02:24 PM
np208 transfercase
I have a 1973 chevy 4x4 4 speed manual tranny 350 engine, the transfer case is shot (its an np208) and i was wondering if a 208 out of an 86 chev with a th400 transmission will bolt up to my standard or if ill need some kind of adapter. Any help is much appreciated.
Thanks
Cody
Old 09-10-2009, 02:38 PM
I think the spline count on the output shafts are different from a 350 to a 400 but not sure
Old 09-10-2009, 03:20 PM
prostreet6t9's Avatar
Differential/Driveline
Thanks
Cody
Are you sure you have a 208? Or did someone transplant it in there?
Old 09-10-2009, 05:20 PM
heathj1's Avatar
Which way to the swap meet??
I thought trucks of that year had a 203 tranfer case made of cast iron? Is thanfer case have an aluminum case or cast iron?
Old 09-10-2009, 07:50 PM
The guy i bought it off of said it was a 208 but it could b a 203 im not 100% sure, if it turns out to b a 203 is it possible to put a 208 or a 205 in?
Old 09-10-2009, 10:19 PM
Both should be 32 spline
Shane
Old 09-11-2009, 01:59 AM
Wiki Edits: 85
Thanks
Cody
Maybe. The 400 spline count is 32 splines. If your standard has 32 output splines it should work.
Edit:
1973 Chev with a 350 engine came only with NP205, NP203, or Dana 20 transfer cases.
Old 09-11-2009, 09:40 AM
I re-read the original post. Your 4 speed will have very course splines maybe 10 and the transfer case from a auto transmission will have fine splines 32.
Old 09-11-2009, 03:58 PM
Is there some type of conversion kit available for the swap?
Old 09-11-2009, 11:35 PM
If its a 208 it should have the adapter spacer.
Shane
Old 09-12-2009, 07:41 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
In reading and responding to your other post here in the transmission and rearend forum, you state you have a manual transmission, in a 1973 GM truck.
Given those 2 facts, your transfer case should have ONLY been either a Dana 20 or a New Process 205.
Just out of curiousity, what makes you think the transfer case is bad in your truck?
Old 09-12-2009, 10:34 PM
its not transfering power to the font driveshaft and it makes a bad grinding noise when its in 4h or 4L, but it does work fine when its not in 4wd
Old 09-12-2009, 11:34 PM
You just may have the NP203 and have a broken chain.What kind of shift linkage is on your's? If you have a 203 you should have a 2L setting. shifter all the forward towards dash is 4L,Then 2L N 2H 4H.
If it is a Dana or a 205 you could try and shift the fork by hand to see if it will go in.You may have a broken shift fork.
Old 09-14-2009, 02:22 PM
i got underneith the truck and scraped all the muck off the t case and the tage says its a new process gear 208, the shift pattern is 2H N 4H 4L (over to the right and down)
Old 09-14-2009, 03:31 PM
Is the T/C all aluminum????
4x4 Trans & transfercase Texjax_blazer Transmission - Rearend 5 02-21-2009 10:12 AM
transfercase or transmission teek Introduce Yourself 1 10-29-2007 08:11 PM
Ford Transfercase Swap N8GNI Transmission - Rearend 4 02-07-2006 04:05 AM
Transfercase Scyclone Project Sycloned Transmission - Rearend 2 06-13-2005 04:56 PM
electronic transfercase shifter chevystuck Electrical 2 07-29-2003 05:26 PM
