nstalling control arm cross shaft bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2013, 05:56 PM
Trophyman's Avatar
Last journal entry: 1939 Chevy Master Deluxe New Project(3)
I need some guidance on installing control arm cross shaft bushings. I am using a pair of Mustang II tubular control arms from Heidts. I need to replace the cross shaft bushings so I called Heidts and got both the Energy Suspensions and Moog part number. They (Heidts) said the bushings fit 65-82 Corvette.
So I get a set of Moog K8219. When I go to install them I canít see how in the world this bushing is going into that hole. The control arm hole is 1.193. The control arm bushing is, at the very end where it goes into the arm 1.405 and at the collar 1.457. (see attached). Can somebody tell me if these look right?
Thanks
Old 07-04-2013, 06:03 PM
BOBCRMAN@aol.com's Avatar
Ain't gunna go. !.405" won't go into 1.193" any way you try..
Old 07-05-2013, 01:00 PM
kso's Avatar
kso kso is offline
Do you mean uppers? Stock on my '72 'vette measures around 1.28, right in between your two numbers instead of being at either. Maybe a patient counterman might pull some boxes out for you.
Old 07-05-2013, 05:29 PM
Trophyman's Avatar
OK, got the answer from STIMPY over on hotrodders dot com. I just installed the poly bushing (Energy Suspension) without the metal collar. Thanks everyone.
control arm bushings Ajkracing Suspension - Brakes - Steering 8 09-29-2010 07:18 PM
1958 Chevy-Upper Control Arm Cross Shaft-HELP!! snowjoe Suspension - Brakes - Steering 2 05-26-2006 02:28 PM
control arm bushings chevypunk Suspension - Brakes - Steering 5 10-30-2003 09:21 PM
Control Arm Bushings 69 chevelle SS Suspension - Brakes - Steering 1 08-10-2003 07:50 PM
Help!!! Control arm bushings! arborlis Suspension - Brakes - Steering 5 03-22-2003 05:57 PM
